Author Topic: slide problems  (Read 4336 times)
Helpful Rating: 73
Best Friends
« on: August 31, 2012, 12:38:20 am »
While cleaning i noticed the wearing of my slide and the rubber falling apart. The factory screws are causing the problem. I replaced these screws with a flush mount counter sunk type. I hope this takes care of the problem. I remember what my dad told me, he should have followed the, "7 P's" I might not had this problem.
Helpful Rating: 144
« Reply #1 on: September 11, 2012, 01:09:32 pm »
Thanks for the tip, Billy.  My seal was also worn by the raised screw heads where the slide was tightest.  I replaced them with flat head screws, I did all the screws just to be sure that another spot might start to wear.  Couldn't get to the center one on the top because of the topper.  Interesting to note that the holes were already countersunk for flat head style screws so the new ones fit flush.
« Last Edit: September 11, 2012, 02:46:13 pm by bobander » Logged
Helpful Rating: 73
Best Friends
« Reply #2 on: September 11, 2012, 01:58:26 pm »
Strange, I needed to do my own countedsink?
I will try to do as many on the top as I can. My last name (Schmall) pretty much tells u my height. rolling on the floor shrug rolling on the floor
« Last Edit: September 11, 2012, 04:45:32 pm by billy » Logged
« Reply #3 on: October 09, 2012, 02:25:37 pm »
Billy and Bob
 What type flat head screws did you use, and what size? Did you use silicon caulk?
Helpful Rating: 73
Best Friends
« Reply #4 on: October 09, 2012, 02:51:45 pm »
There were #8 and I used a #10. First started with SS Countersunk flat head. SS is not a strong head and being oversize they would strip the Philips head,  About the last 6-8 I used zink, if they rust I will replace them. It was necessary to countersink mine. You could drill the hole to a#9 then use the larger screw or just use the #8. I am a little on the wired side Help me!
« Reply #5 on: October 09, 2012, 03:40:22 pm »
I followed Billy's example and replaced most of my screws behind the slide. I found that #8 1" SS worked for me. I started by using brass but way to soft and striped four of them so bad I can not get them back out. I did not have any problems with the SS screws. I could not reach under the slide's awning so they are still the original screws.
« Reply #6 on: October 09, 2012, 03:47:45 pm »
Thanks--Billy, Bob and Tom. Another project now that I've got my cabinet complete.
I think I will use silicone caulk with the SS #8's.
Helpful Rating: 144
« Reply #7 on: October 09, 2012, 06:36:16 pm »
I used #8 - 1" long flat head zinc plated steel screws.  I like the strength of the steel vs brass or sst for this application.  If  I see any sign of rust on the screw heads, I will apply white paint.  I have been on the road for three weeks with lots of rain and no rust yet.  Also, look around the RV and see how many other screws are zinc plated steel with no problems.  I don't think silicone sealer will be necessary as the existing sealing material under the flange squeezes out under the flat head screw.  My 2010 had countersunk holes, if you have drill the countersink then you might need some sealer.
Helpful Rating: 73
Best Friends
« Reply #8 on: October 09, 2012, 07:18:54 pm »
Gradygay, sounds like a plan.     Wink
Anne and Bob
Helpful Rating: 12
PurchDate: May 21, 2012
« Reply #9 on: October 09, 2012, 09:56:21 pm »
We replaced ours with #8 Stainless flathead and put a dab of silicone on the tip of the screw before screwing it in.  Couldn't reach the ones under the awning.  The old screws were chewing the rubber on the slide.  The flatheads so far are working great.  Anne and Bob
PurchDate: 09/2011
IntColor: grey
« Reply #10 on: October 20, 2012, 10:21:31 pm »
I have found young teenagers fit well underneath the awning to change those screws.  Send a responsible young grandchild who thinks the world of his grandpa up there to do the change out.
DJM
Helpful Rating: 73
Best Friends
« Reply #11 on: October 21, 2012, 11:52:48 am »
All my grand kids discovered the opposite sex and grandpa now comes in second.  LOL
« Last Edit: October 21, 2012, 08:02:42 pm by billy » Logged
Helpful Rating: 51
PurchDate: 4-08-2012
Medicine Bow, Wy.
« Reply #12 on: October 21, 2012, 07:01:49 pm »
 (exactly)I still have a few under the age of puberty, so I better get them up on the ladder...  rolling on the floor
