Author Topic: Sani-Con Nozzle Issues  (Read 3609 times)
GeorgeB
Helpful Rating: 7
PurchDate: Aug 2012
IntColor: Slate Gray?
ExtColor: Slate Gray?
« on: September 22, 2012, 11:33:11 pm »
Hello,
Total RVing newbies here, full-time.  Jumped into the deep end of the pool before learning how to swim.  At the end of July we had no idea we would be doing this.  At first, we thought we'd start out with a van conversion or similar.  But by sheer good luck, we ended up with a 2008 PC M-2551 in what seems like reasonably good condition.  We're very pleased that we found one of the few affordable ones here in the Pacific NW.  However...
After about 25 days, the Sani-Con motor quit.  We've had it replaced, also one of the dump valves had frozen partly open (the gray valve).  All seems to be well now.  But the replacement came with hose and nozzle.  So now I have 3 nozzles, 1 old and 2 new, as I had previously purchased a new one about 2 weeks ago.
The problem I'm having is that I cannot get the nozzle to screw into standard 4-inch drains in RV parks.  While waiting for the repair I had to use the 3-inch hose, and had no problems mounting it to the drain with it's 4-in connector.  In the meantime, I have cobbled together a 3-in to 4-in adapter, and screw the Sani-Con nozzle into that using the 3-in portion of the nozzle.  It works, but is more stuff to carry and set-up.  (FWIW, I did try a foam connector, but that was a mistake.)
Any one else have this problem?  I thought I'd check on this forum before researching further.  (I did try an internet search, with pages of results but nothing useful.  Also tried a search on this forum -- so maybe no one else has had this problem.)
Any advice would be welcome.
Thanks in advance,
--George
PurchDate: 6/2011
IntColor: Tan/Gray/Cherry
ExtColor: Lower Slate Gray
« Reply #1 on: September 23, 2012, 08:16:43 am »
Although I cannot offer any suggestions regarding your issue(s), I will offer an observation:
Our use of the PC has changed somewhat in that we no longer do the 'hit and run' of a single overnight but now plant ourselves at a location and use the TOAD to explore from it for 3 or more days.
Consequently, I had the factory install the valve on our PC's 3" 'emergency' drain port and found that while the Sani-Con does the job expected, using the 3" 'stinky-slinky' port provides better evacuation of the black tank's solids. I'm sure this is due to the surge of the greater volume and faster flow of the large port versus the slower Sani-Con system.
njheart on the road
Helpful Rating: 9
PurchDate: 1/2014
Model: 2100
ModelYear: 2014
IntColor: Sunlit leather w/Maple cabinets
ExtColor: Cafe lower body
"Wherever you are, be all there..." Jim Elliot
« Reply #2 on: September 24, 2012, 06:04:48 am »
... I had the factory install the valve on our PC's 3" 'emergency' drain port and found that while the Sani-Con does the job expected, using the 3" 'stinky-slinky' port provides better evacuation of the black tank's solids. I'm sure this is due to the surge of the greater volume and faster flow of the large port versus the slower Sani-Con system.
Bob, what "valve" had to be installed for you to do this? (I was assuming, since we don't pick our new PC up for another week & a half, that one can just use the emergency dump whenever one chooses.) ???
~marilyn
"Wherever you are, be all there. Live to the hilt every situation you believe to be the will of God." Jim Elliot
« Reply #3 on: September 24, 2012, 07:43:47 am »
    The earlier models of PC did not come with the 3" valve, just the Sani-con. My 2010 did come with a 3" opening with a cap mounted just after the pipe turns to the side to go to the Sani-con.  It was to allow one to get access to the drain pipes coming from the black and gray tanks. In 2011 there was some discussions on this forum about this opening. Shortly after that the pictures of the new PC showed a 3" emergence valve from the rear of the motorhome. My 2012 came with this opening with a valve to control the flow to the opening versa just the opening. Some of us like to use the Sani-con for one nighters and the 3" for longer stays. The 3" allows us to open the gray valve and leave it open. We then close it to collect some water, just before we need to dump the black tank. We open the black tank, drain and flush it, close the black tank. Then open the gray again to dump the water, thus flushing the hose with soapy water. It helps to keep the hose from stinking. Never and I repeat never leave the black tank valve open after dumping it and always put at least one bowl of water into the bank. If you don't follow this rule, you will end up with "THE CONE Cry" that will stop up the tube coming down from the toilet. Help It is a major job to remove this cone by using water and a long rod to break up the cone. At a dealer the new guy normally gets this job.  rolling on the floor
    Some campgrounds have the sewer pipe with  threads and some don't. You should be able to insert the end/cone of the hose into the sewer. You will see all kinds of ways to hold the hose in the pipes that are not threaded. LOL
PurchDate: 6/2011
« Reply #4 on: September 24, 2012, 07:54:39 am »
Tom beat me to it with the explanation.
Also, I suggest you occasionally drain the gray water tank using the Sani-Con to get that last little bit of schmutz between the 3" port and macerator out, especially when winterizing.
Helpful Rating: 144
« Reply #5 on: September 24, 2012, 10:39:10 am »
For those new to the Sani-Con, I add my perspective:
I always use the Sani-Con, don't carry a 3" hose (probably should).  When hooked up for extended stay, the Sani-Con bypass hose lets the gray water drain slowly with the gray valve open, it only drains to about 1/3 full.  When getting close to time to drain black tank, I close the gray valve to fill the gray tank for flushing as described by Tom.  I make sure to use lots of liquid in the black tank and have never had the dreaded "cones".  A friend ended up with a horrible mess when he left his black valve open!
The Sani-Con is noisy and could be an issue if you were concerned about dumping with very close neighbors, in these rare cases the 3" hose would be better but I just dump in the middle of the day when nobody is home!
My 2010 model has the 3" outlet but no valve, just a cap.  What advantage is the valve?  Is it there in case the Sani-Con quits in the middle of a dump and removing the 3" cap to hook up a hose would result in a huge mess of "schmutz" as Bob calls it?  If I start carrying a 3" hose for emergency, I will probably add a valve.
« Last Edit: September 24, 2012, 10:52:31 am by bobander » Logged
PurchDate: 6/2011
« Reply #6 on: September 24, 2012, 11:47:26 am »
There is a distinct advantage to having the valve because without it, removing the cap from the 3" port would allow uncontrolled schmutz flow from the "T" section between the macerator and electric gate valves.
Unlike the immortal Carroll Shelby's (1923-2012) statement "If some is good, more is better. And too much is just enough", in this case, just a little is far too much. Embarrassed
GeorgeB
Helpful Rating: 7
PurchDate: Aug 2012
« Reply #7 on: September 25, 2012, 08:52:08 pm »
Yes, I agree with the use of both the Sani-Con for "hit-and-run" stops, and the 3" drain hose for longer stays, or when we want to flush out the tanks.  Since we're still trying to figure all this out, we're experimenting with various methods of dumping, including not dumping at all for a single night if there is no immediate need.
And more than just experimenting, we're practicing.  (Gotta remember to make sure the gray valve is closed before dumping the black!!! Smile
I learned this the hard way.  It is a long way from the end of the 3" dump line to the black dump valve!!!
I found a "twist on dump valve" that just, yes, twists on to the end where the cap sits, then attach the cap to that twist-on valve.  So far works like a charm, it is attached very snugly, so far it seems like it won't accidentally detach.  The cap, however, is another matter:  it was loose, so I wrapped  layers of black electrical tape on the prongs, and it is now firmly attached as well.
As for some other means of connecting the Sani-Con nozzle to the campground's sewer connection:  laying the nozzle without screwing it in would require some form of weight to hold it in place, such as a concrete block, which we don't want to carry, or a large, heavy rock, which is not available at the park where we're currently staying.
FWIW:  I did contact Thetford regarding this, and they have no solution.  I'm currently contacting stinky-slinky sources to see if there is some way to adapt their connectors to the Sani-Con hose.  If I learn anything useful, I'll add it here.
Thanks for all the feedback, I'll be asking more questions, as there is a bunch of stuff we still don't know.  Hopefully there won't be any major damage to the surrounding community in our quest to figure it out.   Grin
--George
PurchDate: 6/2011
« Reply #8 on: September 25, 2012, 09:05:55 pm »
Ask away, we'll be here.
Good luck in the learning experience and be prepared for the usual mistakes. We've all made them.
« Reply #9 on: September 26, 2012, 07:27:42 am »
How about taking a coat hanger, cutting out about 12", bending it into a U. Turn the U over the hose near the end and push it into the ground to hold the hose in place. simple, light weight and easy to store.
PurchDate: 6/2011
« Reply #10 on: September 26, 2012, 08:24:56 am »
Your wife's foot works pretty well too.
Helpful Rating: 296
« Reply #11 on: September 26, 2012, 04:03:39 pm »
George, I never heard of it until your comment.  Though I don't need one myself, that is worthy for your first "Helpful".  Thanks for sharing that one.
For the record, this is what George was describing.  It installs in seconds and is very affordable for around $20 for those who need one last barrier of protection when twisting off the end cap.
« Last Edit: September 26, 2012, 04:08:05 pm by ron.dittmer » Logged
Helpful Rating: 296
« Reply #12 on: September 26, 2012, 04:09:55 pm »
I like your very inexpensive, quick solution idea.  A "helpful" for Tom.
