Pages: 1 [2]   Go Down
Author Topic: testing  (Read 3599 times)
Helpful Rating: 117
PurchDate: March 2012
IntColor: cherry
our 3rd PC--Custom 2910
« Reply #15 on: February 01, 2013, 08:11:35 am »
Aimee,
my only problem with the entire website is the Forum. Everything else displays properly. I use Internet Explorer.
Judi
Helpful Rating: 75
PurchDate: 6/2011
IntColor: Tan/Gray/Cherry
ExtColor: Lower Slate Gray
« Reply #16 on: February 01, 2013, 08:33:00 am »
We're good.
Helpful Rating: 289
« Reply #17 on: February 01, 2013, 08:44:12 am »
Everything seems back to normal this morning here at home.
« Last Edit: February 01, 2013, 12:50:16 pm by ron.dittmer » Logged
aimee
« Reply #18 on: February 01, 2013, 11:28:59 am »
Aimee,
Judi
Thanks, Judi!  Can you tell me how things look now? Whatever was throwing off Ron's is better.  My gut is that it was a DNS cache issue (harder to flush than the browser cache) and that once the "time to live" on the dns cache has passed, it will right itself.  Fingers crossed!
Helpful Rating: 289
« Reply #19 on: February 01, 2013, 12:43:25 pm »
Here at work, I now see that removing all the whte boxes with red X's is something I control.  As Aimee talked about cache, I believe that is the answer.
I ran a free computer program called CCleaner and that resolved the problem by cleaning out the cache and all that.  We use the free version of CCleaner at work.  Irene and I use it on our home PCs too.  It is very safe, reliable, and trust worthy.  I also clean out old registries.
If you are not comfortable download free CCleaner, then you'll have to go into tools/internet options and in there clean out the cache.  Don't ask me which buttons to select there.
CCleaner cleans it all out automatically and also a lot of other garbage elsewhere on your computer like temporary internet files and such.  If you have never cleaned your computer of all that kind of stuff, you will see lots more memory available and your computer should run noticably faster.
If you want to load the basic free version CCleaner, go to this website.
http://www.piriform.com/ccleaner/download
Then select the version on the lefthand side that says "X No Support"
I download from Piriform.com, the lower of the two choices, but either works fine.
Be sure to read through the subsequent forms as you will want to be notified of available updates and take advantage of them.
« Last Edit: February 01, 2013, 12:50:30 pm by ron.dittmer » Logged
Helpful Rating: 289
« Reply #20 on: February 01, 2013, 12:57:36 pm »
Okay, something still is not right.
After all this cleanup, when I go into the For Sale section, the pictures are the white box with red X and I can't get rid of them.
 shrug shrug shrug shrug shrug shrug
Helpful Rating: 289
« Reply #21 on: February 01, 2013, 01:23:51 pm »
Now my little shrug s are X'd
Helpful Rating: 117
IntColor: cherry
« Reply #22 on: February 01, 2013, 02:54:03 pm »
Used CCleaner and now all is good! Thanks.
Judi
aimee
« Reply #23 on: February 01, 2013, 05:19:49 pm »
One down, one to go!  Ron can you use CC Cleaner?
Helpful Rating: 289
« Reply #24 on: February 01, 2013, 05:28:56 pm »
I just ran CCleaner again.  Some things are fixed.  Not everything though.
Some pictures here still have some red X's.
http://www.phoenixusarv.com/community/index.php/topic,91.0.html
The X's are controlled in PC testimonials.
« Last Edit: February 01, 2013, 05:33:28 pm by ron.dittmer » Logged
aimee
« Reply #25 on: February 01, 2013, 05:40:49 pm »
That's my fault.  I renamed the testimonials directory.  Let me see if I can do a quick custom 404 to direct everything from the old testimonials directory to the same file in the new 2013/adventure directory.  If not, we'll just change the address on the images.
Thanks!
Pages: 1 [2]   Go Up
