JoeyD
Helpful Rating: 15 ________
PurchDate: 1/16/2013
ExtColor: Black/Grey
« on: February 04, 2013, 10:04:20 pm » |
I did a search regarding tire pressure and though quite helpful, I couldn't find specific data concerning my 2910T. After having a tire replaced do to a road hazard, the tire adjusted my tire pressure to 90 in the back and 80 in the front. After leaving, I found the ride to be quite "hard". What would be the proper inflation for the 2910 w/triple slide? Thanks again everyone.
Helpful Rating: 98 ________
PurchDate: May 5, 2012
« Reply #1 on: February 05, 2013, 09:03:04 am » |
joeyD:
On my 3100 I run 72 lbs. in the rear and 68 lbs in the front. The coach handles very well and the ride is not as harsh as it is with the 80 plus pounds of pressure. I had the coach on the scales and then went to Michelin's charts to come up with those inflations. I only have one slide so you might be coming in a few hundred pounds over me and the inflations should be a little more but I think 90 lbs in the is way to much and over max for the tires and you will really get that wandering feeling in the front end. best of luck. Ron
« Last Edit: June 12, 2013, 12:28:24 pm by ragoodsp »
SuperHero Member PCPC
Helpful Rating: 426 ________
« Reply #2 on: February 05, 2013, 09:27:53 am » |
JoeyD
The tires (LT225/75R16) on our 2012 2551 are rated for a max inflation pressure of only 80 pounds and we run 72 pounds front and rear. Not sure if PC uses a different tire on the 2910's. Also, max pressure is printed on the side of each tire.
dickreid1
Helpful Rating: 71 ________
PurchDate: Feb. 2012
« Reply #3 on: February 05, 2013, 08:29:49 pm » |
Joey D
I weighed my 2910D and according to the Michelin chart set the front tires to 75# and rear duals to 80#.
Dick
JoeyD
« Reply #4 on: February 05, 2013, 08:49:02 pm » |
Thanks everyone, you folks are the best. I'll knock my mine down to 75 front and 80 rears.
Helpful Rating: 297 ________
« Reply #5 on: February 06, 2013, 12:37:13 am » |
JoeyD,
Assuming you have the same tires as most PC owners do, the max tire pressure as stated on the tires is 80 psi. You don't want to exceed 80 psi.
PC-USA places a sticker on the driver door frame that states what the tire pressure should be for your particular model PC.
On my 2007 PC-2350, the sticker says 60 psi for the rear tires, and 65 psi for the front tires. But I add an extra 5 psi all around because my tires visually look a little under-inflated and also to save a little gas. But more air = harder ride. I once tried 80 psi all around and the rig hit every crack in the road real hard. Needless to say, at our first stop I let out some air.
I keep procrastinating, but I should weigh my rig while on a trip and find out from the tire manufacture's website what the tire pressure really should be.
Oops...I see I have repeated much of what others have said. Then you heard it twice or thrice.
« Last Edit: February 06, 2013, 12:41:32 am by ron.dittmer »
BarbRN
Helpful Rating: 11 ________
PurchDate: May 25, 2013
IntColor: beige
ExtColor: tan
« Reply #6 on: June 11, 2013, 09:47:12 am » |
So, after much discussion in our house, what dictates the tire pressure? Tire manufacturer, chassis manufacturer or motorhome designer?  Seems to me it varies depending on the load and which model is on the chassis and where the weight is distributed with each build. But then, I'm only a girl.
Shipper
Helpful Rating: 12 ________
PurchDate: 04/2013
IntColor: Maple and Grey
ExtColor: Dusk
Cadillac Mountain
« Reply #7 on: June 11, 2013, 10:10:18 am » |
So, after much discussion in our house, what dictates the tire pressure? Tire manufacturer, chassis manufacturer or motorhome designer?  Seems to me it varies depending on the load and which model is on the chassis and where the weight is distributed with each build. But then, I'm only a girl. The weight of the coach loaded dictates tire pressure restricted by the maximum setting per the tire manufacture. The chassis manufacturer has nothing to do with the tire pressure once the chassis has been modified, but the MH manufacturer may have a suggestion restricted by the previous sentence. JMHO.
It's not that I'm insensitive, it's probably that I just don't care.
Helpful Rating: 197 ________
« Reply #8 on: June 11, 2013, 11:14:58 am » |
So, after much discussion in our house, what dictates the tire pressure? Tire manufacturer, chassis manufacturer or motorhome designer?  Seems to me it varies depending on the load and which model is on the chassis and where the weight is distributed with each build. But then, I'm only a girl. It is up to the chassis manufacture to set the pay load based on a number of things like wheels, axles, brakes, fame etc. It is up to the motorhome maker to stay within these limits. The tire manufacture puts the maxmium air pressure for the tires. This is why a four wheel weight is important. "But then, I'm only a girl". If i was trying to be funny, I would say something about the amount of air given off by the different sexes, but I would never say something like that. Oh, no.
BarbRN
IntColor: beige
ExtColor: tan
« Reply #9 on: June 11, 2013, 12:24:07 pm » |
So, after much discussion in our house, what dictates the tire pressure? Tire manufacturer, chassis manufacturer or motorhome designer?  Seems to me it varies depending on the load and which model is on the chassis and where the weight is distributed with each build. But then, I'm only a girl. It is up to the chassis manufacture to set the pay load based on a number of things like wheels, axles, brakes, fame etc. It is up to the motorhome maker to stay within these limits. The tire manufacture puts the maxmium air pressure for the tires. This is why a four wheel weight is important. "But then, I'm only a girl". If i was trying to be funny, I would say something about the amount of air given off by the different sexes, but I would never say something like that. Oh, no. You implied it, enough for me to remember your name!  Air comes from various places don't forget!
« Last Edit: June 11, 2013, 12:26:01 pm by BarbRN »
« Reply #10 on: June 11, 2013, 03:00:15 pm » |
I have nothing more to say about that and that's that.  ....  ....
jampodd
Helpful Rating: 3 ________
PurchDate: 11/2012
IntColor: sunlit
ExtColor: sunlit
« Reply #11 on: June 11, 2013, 03:30:03 pm » |
I just had my 2552 weight and they recommended air pressures. Weights were LF 2160, RF 2100, LR 3820, RR 3780. Total weight 11,800, no water in tanks. Recommended pressure were 65 all around, Although I keep slight over 70 in all and it handles and rides fine. I also had new sway bars, trac bar, sumo springs and shocks put on.
Jim Poddany - 2552
« Reply #12 on: June 12, 2013, 09:00:41 am » |
jampodd:
Your four corner info is great and very valuable. I am impressed that PC has done such a good job of balancing things out so well front to rear and side to side. i am sure a full water tank will change things some. I would say 70 lbs would be perfect for your coach. Now I know why my 2551S never handled exactly the way I would have liked it to....I was running way to much air at 75 and 80lbs! Thanks, Ron
« Reply #13 on: June 12, 2013, 09:57:49 am » |
This discussion reminds me of my uncle who years ago bought an E250 maxi-cargo van for camping in. He said the psi rating on the tires were 55 so he put in 55. He eventually figured out that his load never called for such high psi. At home it was around 30 and on trips he added I think 10 psi more.
BTW: He still has that 1996 E250 maxi-cargo van, and it could pass as a new old-stock van. You could perform surgury in it today. He even keeps it up with wax and all. Cargo vans typically get beat up starting on the first work day.
Helpful Rating: 48 ________
PurchDate: 12/12
« Reply #14 on: June 12, 2013, 10:10:53 am » |
GOOD THREAD and a never ending argument. Many good points, main point never never underinflate and never over inflate,,, would be interesting to see the PSI on your tires after rolling a couple 100 miles in the heat and running at 80psi, wow,,,, I think every rig obviously is different depending upon size, suspension and loaded not loaded. If you wanted to be anal about it you would adjust the psi every time filled up with gas, used your water tank etc etc,,, too much work for me,,, I do check my air every day when traveling. I adjust couple of psi if going dry camping and vice versa more/less weight. Another point,,, altitude.. thinner air above sea level,, I do adjust when I'm running around the mountains for a few days.
WATER TANK-??? I think most of us have the 55gallon tank in the rear.. looking at mind, it looks like it extends the whole width of the rear, so that as it empties the weight is evenly distributed on both sides of the rear tires. Now if your straight dumping with hook ups no problem all the weight is gone, however if your dry camping it seems the tanks are mainly on the driver side rear,, so you have now put a lot of extra weight on one side, considering 400lbs might need to up the psi on the rear driver side a little, especially if not dumping too soon.. Just curious David Sparks 2008 PC 2350 Houston
