Another season on the road and the inverter is not working
  • 4 Replies
  • 1563 Views
ge_montana
  • 93
    • East of Yellowstone
  • PurchDate: January 4, 2012
  • IntColor: green
  • ExtColor: green half
I thought that i had resolved this last year when i discovered a light under the driver running board was always on, and i disconnected it before i drove home. I need some help to disgnose the current problem, we will be here for three days. My inverter is not working see explanation that follows.
We have been on the road for four days, plugged in at night. Yesterday after i just disconnected all shore power i tried to turn on the inverter (XANTREX 1800), by pressing the green button. I get an EO2 message -- an input problem typically from low voltage -- then 9.8 shows up and then only clicking until i press the green button on the inverter again.
Battery connectivity is on "use" not "Store". Ground fault light is not on. What am i missing
greg & kathy
2010
2551S
Greg Matthews
Photographer
EastOfYellowstone.com
  • 1087
Re: Another season on the road and the inverter is not working
« Reply #1 on: May 19, 2013, 06:52:23 pm »
Greg
The first thing I would do is to get a volt meter and measure the voltage right at the coach batteries (not the van battery).
If the reading is less than 12 volts then the battery is not being charged or there is excessive corrosion on the leads or there is a lose connection.
To check for charging the battery, connect to shore power, make sure the store switch is in the operate position, and then measure voltage at the battery.  This will ensure that you are indeed charging the battery.  You should read about 13+ volts.
Also check to see if there are any blown fuses (12 volt) in the convereter.
This is what I would do to start troubleshooting this problem.  Let us know what you find or if you have other quesstions.
Just for your info - I went out to our coach and tested the inverter and I read a full 13.0 when I press the green button.  I'm pretty sure that this is what the inverter sees as the coach battery voltage.
« Last Edit: May 19, 2013, 07:02:52 pm by Barry-Sue »
  • 1087
« Reply #2 on: May 19, 2013, 07:09:13 pm »
Greg,
    I was also thinking, and this happened to me on more than one occasion--I thought I was in the "use" position because the red light was on but in essence I had plugged it in and did not put the button in the use position so I was not charging my batteries.  The red light was only on because I was plugged in.
« Last Edit: May 19, 2013, 07:48:17 pm by Barry-Sue »
  • 306
  • Model: 2700
« Reply #3 on: May 19, 2013, 08:10:38 pm »
Greg,
100% right, cycle the switch at the very least and then check your voltages.
ge_montana
  • 93
  • IntColor: green
« Reply #4 on: May 19, 2013, 08:36:39 pm »
I did a battery test on the coach batteries, not the batteries that start the engine, they were at 13.5 and when tested with a load show are in good shape.
My next trip is to the inverter, which for my 2551 is under the long twin bed. nothing is tripped on the 110 power side, will look a right side in the morning.
Does any one know if there is a master rip to my inverter and if so where it might be.
----- OH Wow! -- Here is a Rosanne Rosanna Danna moment, so never mind, but read on.
Here is an update, i just tripped the fault in the bathroom on and off, and then tried the green inverter button again, it is working. Shows a full 13.5 volts.
This is what happened last summer too. I just do not understand,how one moment it does not work and then later it does work.
Greg
2 552
Greg Matthews
Photographer
