Author Topic: Xantrex 1800  (Read 2847 times)
ge_montana
Helpful Rating: 10
PurchDate: January 4, 2012
IntColor: green
ExtColor: green half
« on: May 25, 2013, 06:00:00 pm »
The inverter is not working again.
After having read all the posts on this inverter, it appears that my MH was built at a time when there were some bad inverters. The prior owners had never run the generator and likely never used the inverter. Will call Kermit on Monday, maybe just need to replace it.
Need help from another owner with xantrex 1800. The fuse box has been labeled by someone with very poor hand writing. Can make out a few of hieroglyphics but other are beyond legible.  Could someone tell me what their two panels have written (right and left side!) for each numbered circuit.
Thanks
Greg & Kathy
2010
2551S
I
Greg Matthews
Photographer
EastOfYellowstone.com
Helpful Rating: 426
« Reply #1 on: May 26, 2013, 09:17:06 am »
Greg
Here is the 120V and 12V panels from our 2012 2551.  Can't be sure yours is the same but it is a good place to start.
120V CB Panel
1.  120V Receptacle
2.  Water Heater
3.  Microwave
4.  Roof Air
5.  Inverter (To Inverter)
30 AMP Main Disconnect (Shore Power or Generator)
20 AMP main Disconnect (Inverter Power From Inverter)
1.  120V Receptacle (Inverter Powered)
2.  Television (Inverter Powered)
3.  Vacant (Inverter Powered)
4.  Vacant (Inverter Powered
12V Fuse Panel
1.  Tank Heater
2.  Driver Side Lights and Livingroom Fan
3.  Passenger Side Lights and Bedroom Fan
4.  Coach Rear Lights and Bathroom Fan
5.  Water Pump
6.  Water Heater/Refrigerator
7.  Antenna/Awning
8.  12V Bath Outlet (Added by factory during build)
9.  O2/Propane Detectors
10. Vacant
11. Vacant
« Last Edit: October 08, 2013, 04:01:40 pm by Barry-Sue » Logged
« Reply #2 on: May 26, 2013, 03:02:15 pm »
Greg, Our 2013 2350 breaker and fuse panel read almost the same as Barry's (also in almost indecipherable writing):
120V CB Panel:
1.  Receptacle
2.  Water Heater
3.  Microwave
4.  Roof Air
5.  Inverter 30
     --20
     --30
6.  Inverter 20
     --20
7.  Receptacle/Television
8.  Vacant
12V Fuse Panel (1 to 7 are 20 amp, 8 is 3 amp):
1.  Tank Heater
2.  Driver Side
3.  Passenger Side
4.  Coach Rear
5.  Water Pump
7.  Antenna/Awning
8.  Detectors
9 to 15 Vacant
« Last Edit: May 26, 2013, 03:03:57 pm by Bruce and Sharon » Logged
Helpful Rating: 51
PurchDate: 4-08-2012
Medicine Bow, Wy.
« Reply #3 on: May 26, 2013, 07:57:23 pm »
Once determining the fuse layout for 120v. and 12 v layoit... good idea to relable them so one knows in the future.
ge_montana
Helpful Rating: 10
IntColor: green
« Reply #4 on: May 27, 2013, 07:22:13 pm »
Thanks, got it now, my set up is a little different but with these i was able to figure what the handwriting said.
However, the passenger fan and driver fan. That seems strange?
Thanks again, this was a big help.
Greg & Kathy Matthews, in Clayton Lake, New Mexico, nice reservoir and pretty camp sites each with a 12 by 12 sun hut to hide under.
Today passed a PC somewhere north of Amarillo that was going south.
Greg & Kathy
2551S
2010
Greg Matthews
Photographer
« Reply #5 on: May 28, 2013, 12:27:59 am »
Very interesting thread and educational.   First thing I am going to do is take greg's course of action and do some preventive medicine on the hinges one way or the other.  It would seem anyone owning this type of frige would do this ASAP.  Even if under warranty, why wait for a problem in the middle of a trip This goes back to the  2007?? and now 2012 units makes no sense.  Is norcold still making this mistake?  Or are these a bunch of friges built 07/08 and still being put in units?  I saw post on another forum on a RV mf,, purchased a bucnch of components and used them for a couple of  years. I think it was microwaves but not sure...   Also, wasn't 07 08 09  very slow years in the  RV business,  so a manufacturer builds too much,, RV mf  gets a good deal....Anyway glad this came up,,,
Houston
ge_montana
Helpful Rating: 10
IntColor: green
« Reply #6 on: June 14, 2013, 08:37:43 am »
Here is follow up to my Xantrex issue.
Spoke to Kermit about the intermittent problem and he suggested since the problem has been dogging me for two years, the inverter probably has a problem. So yesterday i ordered a new 1800 about $460. Stayed with Xantrex to use all the exiting plugs.
After i ordered the new unit, i went out to the motorhome and checked the battery, tried the green on button nothing but "-- -- --" then i once again pressed the reset button on the Xantrex -- as Kermit had suggested -- it is on the lower side of my side mounted unit. Then i tried the green button again, nothing. then i turned the vehicle from "use" to "store" to "use" and for the hell of it pressed the green button on the unit, the TV came on!
I am going to replace the unit anyway, the the only thing that can go wrong after that is with the nut behind the steering wheel.
Greg & Kathy
Greg Matthews
Photographer
ge_montana
Helpful Rating: 10
IntColor: green
« Reply #7 on: June 20, 2013, 09:15:53 pm »
End of Chapter one:
Just got my new Xantrex 1800 and replaced the one that was misbehaving.
All is working now for the first time. So Kermit was right, the inverter was bad. For the first time the monitor is working.
Wow, now for our next trip
Greg Matthews
Photographer
