Check my understanding of battery voltage status
  • 18 Replies
  • 5337 Views
bentgypsy
  • 13
  • Location: NM & CO in the summer. Patagonia, Arizona in the winter.
Re: Check my understanding of battery voltage status
« Reply #15 on: September 02, 2013, 10:14:49 am »
Re my ordered 2350:  I'm planning use the two Lifeline AGM 6V batteries wired in parallel in my present RV.  Will the battery charger still see them as one battery and will I need to buy a charger specifically for 6V batteries?
I assume the Converter will still function as a 3-stage battery charger (?)
Steve
  • 1109
« Reply #16 on: September 02, 2013, 10:41:32 am »
Steve
There are a lot of different aspects to what you want to do.  I would suggest you contact the factory at 574-266-2020 and discuss in detail all of your concerns.
  • 304
  • Medicine Bow, Wy.
    • Weather at my home
  • PurchDate: 4-08-2012
« Reply #17 on: September 02, 2013, 06:58:33 pm »
What we did was order our 2350 without gen.  Then had another battery box mounted in its place.  Then with 300 watts of solar we dry camp for a week without running batteries below 12.4.  I consider we use a lot of watts cuz my ham radio's and TVs/DVD's take a lot.
Just another food for thought?
BTW coffee is ether perked on stove or via coffee maker just depending on battery condition which is Dependant on old Sol.
Denny
  • 358
« Reply #18 on: September 04, 2013, 07:37:51 am »
You treat 2 6v batteries wired in series the same as a 12v battery. A 12v battery has 6 cells wired in series a 6v battery has 3 cells, so two 6v batteries wired in series have 6 cells just like a 12v.
You may ask why PC uses 6 v batteries. The batteries they use are more expensive and designed for many charge-discharge cycles. They will last longer and work better than the old 12v batteries they used a few years ago.
The truth about charging batteries is the converter charger does not put out enough voltage to fully charge your batteries. That's why a solar panel with a charge controller will get the batteries up to 100% charge.
