Author Topic: CB Antenna  (Read 2456 times)
Helpful Rating: 425
« on: July 19, 2013, 03:34:54 pm »
We like to have a CB with us when we travel the interstates so we can get up to date information on traffic conditions from the truckers. In the past I used a magnet mounted antenna but decided to go to a permanently mounted antenna.
The installation was very easy.  I used an existing bolt and nut plus had to drill a hole in the lip of the fender (this was the hardest part of the job, not physically but mentally) for a second bolt and nut (everything is stainless steel).  The cable runs across the top of the firewall, into the passenger fender and through a existing unused grommet into passenger compartment.  I used a 9 foot cable but if I had to do it again I might go with an 18 foot cable for a little more slack once I got into the PC.
Here is a list of parts and sources I used.  Both vendors were very fast and responsive.
Kalibur KVAN Stainless Steel Hood Channel Antenna Mount
http://www.amazon.com/Kalibur-Stainless-Channel-Mobile-Antenna/dp/B000WD3MHI/ref=sr_1_fkmr3_1?ie=UTF8&qid=1374260663&sr=8-1-fkmr3&keywords=cb+van+hood+mount
Firestik FL-3 Antenna
http://www.truckers-store.com/store-products-fl3-4-FireStik-Light-Weight-Mechanical-Tunable-Tip-FireFly-Series-40-Channel-Plus-CB-Antenna_40127053.html
FireStik Fire-Flex 9 ft. Antenna Coax
http://www.truckers-store.com/store-products-k8r9-FireStik-Fire-Flex-9-ft-Single-Antenna-Coax-with-PL-259-FireRing-Termination_40129629.html
Helpful Rating: 73
Best Friends
« Reply #1 on: July 19, 2013, 10:29:42 pm »
Barry, did u install? Did u check the SWR, standing wave ratio?
Helpful Rating: 425
« Reply #2 on: July 20, 2013, 08:55:35 am »
Billy
Yes and Yes.
Out of the box SWR for CH 1 was about 1.2 CH 40 above 3.
After adjusting antenna - Ch1 1.6 CH 40 1.7
GoPhoenix
PurchDate: 12/2010
IntColor: Slate grey/Cherry
ExtColor: Full body grey
« Reply #3 on: July 31, 2013, 12:57:47 pm »
Here's our antenna.  Factory installed when built.  The box to connect the antenna and CB is under the driver's seat.  Power wire under the floor mat.
Helpful Rating: 425
« Reply #4 on: July 31, 2013, 01:59:48 pm »
I didn't have the foresight to have the factory install a CB antenna and I was not going to be allowed to drill a hole in the side of the PC.  This is what I had to do.
Is your antenna a No Ground Plane or a Ground Plane?
Helpful Rating: 289
« Reply #5 on: August 01, 2013, 01:19:06 pm »
I love GoPhoenix's CB installation.  If I wanted a CB, I would be talking with you.  For me though, the CB antenna would need to fold below the height of the a/c unit to get inside our garage.  I'm sure it could be worked out.
GoPhoenix
PurchDate: 12/2010
« Reply #6 on: August 02, 2013, 01:50:04 pm »
Actually, this is my second PC.  On the first PC, I drilled a hole above the driver's door, running the wire into the storage area above the drivers seat, and did the same basic installation.  Of course, wasnt able to run it through the wall like the factory did, but pried up the trim and ran it down that way. Its a No-Ground Plane:
http://www.rightchannelradios.com/firestik-ngp-antenna-side-mount-kit-right-channel-radios.html
Also, have a Quick Disconnect when I store it so that the antenna isnt exposed to the weather during storage (no inside storage, unfortunately):
http://www.rightchannelradios.com/firestik-cb-antenna-quick-disconnect.html
Helpful Rating: 289
« Reply #7 on: August 02, 2013, 02:45:47 pm »
Quick disconnect is good to know.  Thanks!
