Author Topic: Tank heater(s) -- 2008, 2900 PC  (Read 1192 times)
detspcl
Helpful Rating: 2
PurchDate: april/2011
Model: 2900
ModelYear: phoenix cruiser
IntColor: cherry
ExtColor: full body paint
« on: October 10, 2013, 12:17:57 pm »
Anyone,
I have a tank heater switch on my unit but have a basic question: Does it heat ALL of the tanks on the 2900 or just the grey and black water tanks?
Thanks!
Chuck K.
Helpful Rating: 288
« Reply #1 on: October 10, 2013, 12:43:44 pm »
This applies to all PCs with tank heaters.  They heat just the gray and black water tanks, nothing else.  The 12v heating pads are bonded to the underside of the two tanks.  Then the tanks get wrapped in a foil-looking insulation.  You won't be able to see the heating pads.
The rest of the motor home plumbing & fresh water tank is inside the insulated rig.  As long as the interior is kept warm, nothing should freeze.  But there are limits.  I would imagine that you'll have trouble under subzero conditions.
I think the most vulnerable things freezing are the dump valves, based on stories read on RV forums.  The tank heaters will radiate warmth only so far down the pipes.
« Last Edit: October 10, 2013, 12:54:55 pm by ron.dittmer » Logged
Helpful Rating: 167
PurchDate: May 2013
IntColor: Sunlit & Cherry
ExtColor: Sunlit
« Reply #2 on: October 11, 2013, 07:50:28 am »
Another potential freeze zone is the outside shower. I haven't crawled around yet to see if there is a shutoff valve for it but I've read on the forums where people have forgotten to winterize that line and it froze.
Spiritofthewoods.net
detspcl
Helpful Rating: 2
Model: 2900
IntColor: cherry
« Reply #3 on: October 11, 2013, 12:48:57 pm »
Thank You! The mystery is solved!
cheers
Chuck K.
