Generator won't start
  • 18 Replies
  • 5099 Views
JoeyD
  • 77
  • PurchDate: 1/16/2013
  • ExtColor: Black/Grey
Re: Generator won't start
« Reply #15 on: November 18, 2013, 02:37:16 pm »
Start the engine and let in run for a minute than start the generator...
JackD
  • 201
  • PurchDate: 2017 (latest)
  • Model: 2350 Sprinter
  • ExtColor: Greystone
« Reply #16 on: December 01, 2013, 06:10:27 pm »
Hey Guys! Sorry you had the problem, but glad you got it resolved! I bad a problem with mine as well but it was a propane situation (with the sprinter) so not the same: HOWEVER, I have now scheduled to run it at least once a month, (recommended by many) to be safe. It's one of those things that is only needed when you (we) need it.
We'll be emailing you - all the best,
Jack (& Linda)
  • 334
  • PurchDate: 12/12
« Reply #17 on: December 01, 2013, 08:14:59 pm »
I'm curious,,, does the manual recommend running the gen the same for propane?  I understand the reason with the gas due to varnishing in the carb etc... BTW, from everything I have read your not going to hurt the gen by running it,,, that's what they are designed for...
JackD
  • 201
« Reply #18 on: December 02, 2013, 05:05:24 pm »
Yes, it's good to run it regardless - you're right on about the gasoline. My problem (I think) is I filled the propane in Yellowstone last summer, and I read somewhere that often big users get a mixture with more butane in the summer - this supposedly doesn't work as well in winter. I'm a little beyond the scope of my book in this but for whatever reason it wouldn't run/start until I had fresh fill with propane (it only took 2 gals. So it wasn't the low volume problem) .
Best,
Jack
