Awning Support
  • 8 Replies
  • 3377 Views
bowtorc
  • 14
  • PurchDate: 11-26-13
  • IntColor: CAFE
  • ExtColor: CAFE FULL
Awning Support
« on: January 19, 2014, 06:22:08 pm »
 I have a full length electric awning on our 2910D that is sagging in the center.  I cannot find any type of support for the curved side wall .. Any ideas would be appreciated.
  • 862
Re: Awning Support
« Reply #1 on: January 20, 2014, 07:22:06 am »
Call the factory. Our 2013 2552 has a center support on the side wall. We didn't order so it must be something they started to install at some point. It might be from Dometic but I don't really know. It was just there. You can see it in the pictures of the new 2552's on the inventory page. I'm sure you can order through Phoenix or they can tell you where to order one.
« Last Edit: January 20, 2014, 07:27:14 am by 2 Frazzled »
Re: Awning Support
« Reply #2 on: January 20, 2014, 07:54:27 am »
Go here: http://www.campingworld.com/shopping/item/dometic-awning-cradle-support/10924
Check with Carol at the factory, it might be cheaper from her.
« Last Edit: January 20, 2014, 08:34:23 am by TomHanlon »
bowtorc
  • 14
  • IntColor: CAFE
Re: Awning Support
« Reply #3 on: January 22, 2014, 11:07:08 pm »
  Thanks for the help.  They are sending one free of charge from the factory.
bowtorc
  • 14
  • IntColor: CAFE
Re: Awning Support
« Reply #4 on: January 24, 2014, 02:28:51 pm »
 heartshower
Carol is the greatest!! After you guys recommended we call Carol, are happy to report, she is sending out a support to us. Way to go Phoenix Cruiser USA. Thanks to all of you, Roger and Deb
Re: Awning Support
« Reply #5 on: January 26, 2014, 03:38:52 pm »
After giving you a helpful , I should have said thank you. I also have one on order now.
  • 527
Re: Awning Support
« Reply #6 on: January 27, 2014, 03:05:06 pm »
Carol is right on the ball for sure!  The price that she quoted me for my 2012 was considerably more compared to Campers World and the link above.  I can not believe there is any difference between  CW's and the one she secured but I guess one will find out.   thanks
  • 128
  • Cadillac Mountain
  • PurchDate: 04/2013
  • IntColor: Maple and Grey
  • ExtColor: Dusk
Re: Awning Support
« Reply #7 on: February 06, 2014, 10:01:23 am »
If they didn't install the support at the factory, I would want to know if the backing for the bolts is present. I would get the mounting location from Carol also. Lot of weight on that bracket at least on the longer awnings. Just a thought!
  • 527
Re: Awning Support
« Reply #8 on: February 07, 2014, 11:06:22 am »
The Domectic support comes with a small aluminum palte that can be utilized to spread the pressure out some if center does not land directly on one of the studs.  I have yet to put it on yet, wiaiting for warmer weather.  You are suppose to place in center, touching the awaining and then raise it 1/4" before screwing it in with the two supplied cap screws.   My awning is really not sagging to much but I can see how it could start to sag over time.   ths.
