New truck battery
  • 9 Replies
  • 1894 Views
GoPhoenix
  • 285
  • PurchDate: 12/2010
  • IntColor: Slate grey/Cherry
  • ExtColor: Full body grey
New truck battery
« on: February 26, 2015, 08:06:53 am »
I may have to replace my truck battery.  It was totally dead, and Iím trying to charge it.  In looking for a replacement (Advance Auto and AutoZone the only stores in our little town), I found at Advance Auto: AutoCraft Silver Battery, Group Size 65, 750 CCA, $131.99, good reviews.  The specs say ďAuxiliary Battery; Requires special deep cycle battery.Ē  My question is: is the original battery I have now considered a deep cycle battery?  Should I have the charger setting on Deep Cycle?
KB9OMH
  • 170
  • PurchDate: 3/26/13
Re: New truck battery
« Reply #1 on: February 26, 2015, 08:59:01 am »
Gary,
     As a rule you don't use a deep cycle battery for a starting battery, but the spec. on this battery does say it has the cca being good, the review I read were both good and bad.
KB9OMH
  • 368
« Reply #2 on: February 27, 2015, 08:31:00 am »
I don't understand "Truck Battery".
Do you mean the 2 RV batteries or the Engine battery under your hood?
The 2 are Deep Cycle but the engine battery is a standard car battery.
All lead acid batteries are charged at the same voltage.
GoPhoenix
  • 285
« Reply #3 on: February 28, 2015, 05:49:35 am »
I mean the Ford truck battery, not the two deep cycle coach batteries.
  • 368
« Reply #4 on: February 28, 2015, 07:36:04 am »
So any standard car battery of the same group size is fine. Interstate is a good brand,
bobojay
  • 102
  • Model: None
  • ExtColor: Desert Sand-Lower
« Reply #5 on: February 28, 2015, 08:48:55 pm »
If you buy from Advanced Auto, be sure to go online and grab one of their coupons from their website.
It can save some real $$$$. And check the battery mfg date so you don't buy one more than a couple months old
Bob & Sharon
GoPhoenix
  • 285
« Reply #6 on: February 28, 2015, 08:56:34 pm »
Well, that doesnít really address my question about the Advance Auto AutoCraft Silver Battery and why the specs say ďAuxiliary Battery; Requires special deep cycle batteryĒ when it is advertised as an exact replacement for a Ford E450 (Advance Auto and AutoZone the only stores in our little town).
It may a moot point now as the battery finally took a charge.  But now a new problem.  After disconnecting the battery, cleaning the terminals, reconnecting and charging, the review camera monitor stays on even with the ignition turned off.  The compass and thermometer in the rearview mirror also stay on.  Very weird.  Suggestions from anyone?
  • 368
« Reply #7 on: February 28, 2015, 10:13:41 pm »
The switch next to the steering wheel that allows you to charge your engine battery may still be on, it makes my step go in when it is on and door closed.
Dutch
  • 10
  • PurchDate: March 2014
  • ExtColor: Sage/White
« Reply #8 on: March 01, 2015, 04:32:29 pm »
Last week I had to replace the engine battery in my 2011 model 2551. It had been in storage for the winter and wouldn't crank. I had to jump start it to bring it the 10 miles to home. When I turned off the engine, I noticed the fuel gauge jumped to beyond full and the back up camera stayed on. The next morning, it just barely started so I took it to a local auto/truck service center where they tested the battery. It was too far gone to hold more than a 10% charge. Replaced it with a new Interstate 750cca battery and my fuel gauge and camera problems disappeared. Evidently, proper the functioning of certain gauges and options in the RV are affected by low battery output. Not sure but it seemed that way in my case.
GoPhoenix
  • 285
« Reply #9 on: March 01, 2015, 06:46:31 pm »
Wow, keelhauler.  If you were here, Iíd give you a big kiss; well at least firm handshake.  The switch was on (from trying to start the engine).  After turning it off, the compass/thermometer in the rearview mirror, the rearview camera, and the step, all starting working correctly!  I did give you a helpful vote.  Great.   2o2
