Fuse for Sewage pump on Sprinter????
  • 1 Replies
  • 1249 Views
campman1
  • 10
  • 2
« on: November 01, 2010, 04:27:48 pm »
My Sewage Pump quite in the middle of a dump.    Before I contact Factory can anyone tell me where the Fuse is for pump on a 2010 Sprinter 2350?  Thanks.  Ron
  • 740
  • 117
  • our 3rd PC--Custom 2910
Re: Fuse for Sewage pump on Sprinter????
« Reply #1 on: November 01, 2010, 06:17:42 pm »
 Your macerator pump may be jammed. Take the cap off the motor side. With a large screw driver, see if you turn the motorshaft. If it doesn't turn, the pump is jammed. Try turning it with more pressure, back and forth. Hopefully, that should free it.
I don't know where the fuses are.
Good luck!
