Stabilizing Dinette Table (Table With Two Poles)
  • 0 Replies
  • 511 Views
  • 4356
« on: September 10, 2018, 08:55:51 am »
I finally got around to a solution with our dinette table with two poles.  Irene and I are both very pleased with the results.
The problem was when one of us leaned on the table, it would tip.  Not a lot, but enough to slosh a drink too much causing a spill.
I mounted a board along the outside wall, added a full-covering strip of soft Velcro over it, and added a tiny piece of mating Velcro to the underside of the table-top.  Now the table is extremely stable.   I cut angled corners to the stabilizer board to eliminate a sharp corner to get hurt on whether setup as a dinette or setup as a bed.
The black Velco strip is the soft portion, 2" wide, rolled over the edge down the side a bit.  It acts as a soft cushion to prevent squeaking and such.
Adding a 2" long piece of mating Velcro on the underside of the table-top is enough to increase stability.
Too much Velcro would make it difficult to remove the table.
Here you can see I counter-sunk the wall-side holes larger to clear the anchor heads.
If not done, the board would not lay flat against the wall.
I bought these wall anchors but had to use extra long screws to pass through the board.
« Last Edit: September 10, 2018, 09:03:52 am by Ron Dittmer »
