Helpful Rating: 73 ________
Location: Coarsegold, Ca. About 20-25 miles S/W Yosemite ________
Best Friends
« on: January 02, 2011, 03:45:41 pm » |
Is it 4 or 7 way receiver on the back for tow car.
We are considering the 2552 with the dinette, How hard or easy is it to put the table up or down.
« Last Edit: January 02, 2011, 04:15:53 pm by billy »
Helpful Rating: 144 ________
« Reply #1 on: January 02, 2011, 04:14:25 pm » |
7, I run lights and brake controls for the toad through the connector. Bob
2010 PC 2551
SuperHero Member PCPC
Helpful Rating: 197 ________
« Reply #2 on: January 02, 2011, 04:23:51 pm » |
It is a 7 way round plug on the rear.
Helpful Rating: 71 ________
PurchDate: May. 2014
ModelYear: 2551/2014
IntColor: Hickory
ExtColor: Cafe'
« Reply #3 on: January 02, 2011, 05:56:41 pm » |
Billy, Just a few thoughts on the dinette. The table goes up and down very easily. Lift the aisle end up, fold the table leg up and lift off the brackets on the wall. Then lower the table to the support brackets on the edge of the seats. We found the dinette was not very comfortable to sit and relax on as it is very upright seating and to sit with your back against the wall, not too comfortable with the window shade brackets behind you. Also, one person has their back to the TV. We also found the table makes a lot of noise when on the road from road vibrations and that is why we left it down and covered with the cushions while on the road. We had the dinette in our 2350 and in our 2552 we opted for the couch. We will get a pair of short table legs for the table, my wife will make a cushion for its top and we will use it as an ottoman. That way we can sit together and relax. Just my thoughts. Bob
Best Friends
« Reply #4 on: January 02, 2011, 06:54:03 pm » |
We are going to try using the dinette as a combo. We've looked at a couple other B+'s and with the two large pillows we have, with the dinette cushions down my wife thinks we could use the two pillows against the frig wall? Not against the window. Just a thought? The 2552 would have a chair opposite the dinette. About now we've looked at so many I'm getting a little rummy
Helpful Rating: 39 ________
PurchDate: May 15, 2012
IntColor: Sterling
ExtColor: Sterling
« Reply #5 on: January 02, 2011, 06:55:26 pm » |
Bob, great idea getting short legs for the table to use as an ottoman. I'm going to try that--thanks
Firebird
« Reply #6 on: January 02, 2011, 07:24:18 pm » |
Does either the dinette or couch in a 2551/2552 have any seat belt positions, or the ability to add them? Does it make a difference if it has a slide or not? I don't see any seat belts in the PC pictures, but have seen them in some other brand B+ model pictures. Thanks.
IntColor: Hickory
ExtColor: Cafe'
« Reply #7 on: January 02, 2011, 07:50:32 pm » |
Firebird, Our 2350 (2010) had a dinette with no slide out and the dinette had seatbelts, if I recall correctly, on both sides. Our 2552 with a slide and couch has seatbelts for the couch.
pyrthkr
« Reply #8 on: January 02, 2011, 08:16:54 pm » |
My 2008 2551 has seat belts (2) for the couch and it is in a slide out.
Best Friends
« Reply #9 on: January 05, 2011, 06:12:18 pm » |
oooops, I fibbed, I have a 6 way rear plug. Can't even count. Any others with 6 way plug for toad?, billy
Helpful Rating: 300 ________
« Reply #10 on: January 06, 2011, 03:15:33 pm » |
On our 2007, we have the standard 6 wire, 7 terminal plug. The center terminal is not utilized in the wiring.
Our old tow vehicle did hot have secondary breaking, so we utilized a 4 pin harness between vehicles.
Our new tow has secondary braking, so we utilize all 6 wires.
Helpful Rating: 44 ________
PurchDate: Used to own a 2700
Model: 2700
Slide: Yes ________
« Reply #11 on: January 07, 2011, 09:38:50 am » |
Might want to run power from the MH to the toad through that unused center wire. Keeps the battery in the toad up, from the aux brake system and lights.
« Reply #12 on: January 07, 2011, 01:15:37 pm » |
One of the six wires already offers that, supplying power to the tow vehicle's battery.
« Last Edit: January 07, 2011, 01:17:29 pm by ron.dittmer »
