Pages: 1 [2]   Go Down
Author Topic: 2552 Mods/Improvements /Captions  (Read 4980 times)
Helpful Rating: 71
PurchDate: May. 2014
ModelYear: 2551/2014
IntColor: Hickory
ExtColor: Cafe'
« Reply #15 on: January 21, 2011, 02:06:18 pm »
  They do not come with double-sided tape, but I suppose you could use tape.  Mounting it with screws is not a problem as if you remove it you just seal the holes with white silicon sealer.  Cosmetically you can see something was there, but functionally it is as good and secure after the fix.
If they are mounted where mine are, for the most part they are out of the major water zone.  Plus, I am not sure how strong double-sided tape is. Hope this helps.  Also, for info on the rails on the wings.  The bottom of the rail is probably 1/2 inch tall and is hard against the fabric on the wing, so I think placing coins, etc. up there would be no problem.
« Last Edit: January 21, 2011, 02:12:45 pm by gl1500 » Logged
Helpful Rating: 297
« Reply #16 on: January 21, 2011, 02:33:14 pm »
Bob, Thanks for the clarification!  Ron
« Reply #17 on: January 21, 2011, 04:02:37 pm »
Ron, If you want to tape them up, you might want to look into the "Command bathroom tape" by 3M. It is the same tape as used on the Command hooks only for bathroom humitiy.  I used it in the shower to hold two soap dishes on the wall with the shower. Now problem so far and they can be removed cleanly if I ever need to.
Helpful Rating: 51
PurchDate: 4-08-2012
Medicine Bow, Wy.
« Reply #18 on: April 25, 2012, 06:16:09 pm »
Am interested in seeing the pic's from the orig GL1500 post, but don't know what I am doing wrong as the link is not there.
Thanks
Helpful Rating: 71
IntColor: Hickory
ExtColor: Cafe'
« Reply #19 on: May 02, 2012, 02:41:25 am »
K9aeg,
   Click on
Click on SEARCH at the top of the page and type in 2552 Mods/Improvements under Search For,  and user Gl1500.  This should get you to the pictures.
Frank
Helpful Rating: 18
PurchDate: April 2012
IntColor: green
ExtColor: green
CHEERS 2008 2551 (Yooper Kermit)
« Reply #20 on: May 02, 2012, 01:29:14 pm »
Tried Bob, but got no results.
Frank
Frank & Dee  CHEERS!!
« Reply #21 on: May 02, 2012, 01:37:56 pm »
Frank you have to use the Search in the upper left hand side next to the help and profile. Then just put the search and you should get them all four of them.
Helpful Rating: 51
Medicine Bow, Wy.
« Reply #22 on: May 02, 2012, 05:49:53 pm »
ok .. got it.. thanks
Helpful Rating: 426
« Reply #23 on: May 02, 2012, 05:51:01 pm »
Frank,
    If you go to the search screen you can just type in the word mod and all kinds of modifications will show up.  Then you just have to pick and choose what one you would like. Many of the 2551 mods will work on a 2552.  You will have to weed out those post that show the word model but by just reading the portion of the post that is shown in the search results it is not too bad to do.   Have fun and ask any questions you want.  There is always someone on this forum to help.
Frank
Helpful Rating: 18
IntColor: green
ExtColor: green
« Reply #24 on: May 04, 2012, 02:44:04 pm »
That worked Sue, thanks.
Now if I can only figure how to get our photo on
the prefile I'm in good shape.
This doesn't come easy to an old fart!
Frank
aimee
« Reply #25 on: May 04, 2012, 05:21:17 pm »
Can anyone help Frank figure out how to get his photo posted to his profile? Mine has a lot more options than everyone else's does so I can't walk through it and give him step-by-steps.  ThankYou
Pages: 1 [2]   Go Up
