Helpful Rating: 73 ________
Location: Coarsegold, Ca. About 20-25 miles S/W Yosemite ________
Best Friends
« on: March 26, 2011, 04:10:05 pm » |
On my new Cruiser I found rusted screws and thought I would change them to Stainless. I remove one rusted screw and water came out the hole. The ladder being folded I drill a four-¼ inch holes in the bottom of each leg and lot’s of water came out!
Helpful Rating: 44 ________
PurchDate: 09/2011
IntColor: grey
« Reply #1 on: March 26, 2011, 08:24:24 pm » |
Billy:
How about more clarification here. ?Is this something we all ought to check out? How much water? What screw did you pull out? Hints and suggestions?
I am beginning to wish my pole barn was heated so that I could tinker all winter like you people. HMMMM? You think I could convince the other half that heating the pole barn is a great idea and a necessity???
David
family is a passion...work is a requirement 2012 2552 full body paint(Phoenix # 2)
Best Friends
« Reply #2 on: March 26, 2011, 08:51:01 pm » |
When I folded my ladder in the up position I noticed the screws that hold on the black plastic (hinge part) the flat head screws were rusting. I removed one screw (that holds the black hinge thingy on) to see if a stainless steel screw I had would fit, thats when the water came out of the screw hole. So I drilled a 1/4" hole in all four leg bottoms. (Those black thingys) Is thingy a word????????
SuperHero Member PCPC
Helpful Rating: 197 ________
« Reply #3 on: March 27, 2011, 09:31:07 am » |
Thanks Billy,  I just went out into the cold and drilled the holes in the black plastic hinge. Water came out of one of the top legs. The ladder already had a hole in the bottom. I have seen water come out of it in the past.
Helpful Rating: 39 ________
PurchDate: May 15, 2012
IntColor: Sterling
ExtColor: Sterling
« Reply #4 on: March 27, 2011, 01:06:13 pm » |
Had water in both legs of my ladder. Thanks for posting--probably should add this topic to the general area, too. Now I have to go dry off my drill...
Best Friends
« Reply #5 on: March 27, 2011, 08:02:50 pm » |
Sorry about the drill.
Helpful Rating: 297 ________
« Reply #6 on: March 28, 2011, 01:19:13 pm » |
I don't have that problem. Sorry, I couldn't resist.
« Last Edit: March 28, 2011, 05:22:58 pm by ron.dittmer »
Best Friends
« Reply #7 on: March 28, 2011, 02:42:32 pm » |
Ron, just couldn't bite your tongue any longer,
PurchDate: 09/2011
IntColor: grey
« Reply #8 on: March 28, 2011, 03:34:19 pm » |
Ron;
I was wondering how long it would take you to chime in on this. I need the ladder to get my kayaks up top. I also have found that the roof is a good place to get away from the kids and my honey. lol
DJM
« Reply #9 on: March 28, 2011, 05:22:25 pm » |
Sorry for that lame joke. I never meant to imply it's a bad idea to have a ladder and rack. It's just not for me....at least not just yet. I came from a different mold than most.
I do have my roof rack and ladder stored in my "other" house in case I ever change my mind.
DJM, that was funny......hiding up top to get away.
« Last Edit: March 28, 2011, 05:26:44 pm by ron.dittmer »
Best Friends
« Reply #10 on: March 28, 2011, 07:03:03 pm » |
I didn't think it was lame. Thought it was pretty good.
IntColor: Sterling
ExtColor: Sterling
« Reply #11 on: March 28, 2011, 07:05:25 pm » |
Ron, I did think about you when I was drilling my ladder legs, that you wouldn't have to do this. One advantage I've found with having the ladder is using it to absorb the impact instead of the mh when backing into an overhang while looking in the wrong direction. I've kept the dent in the top of the ladder to constantly remind me to look up as well as side to side--old dog, old tricks, old blunders..  .
PurchDate: Used to own a 2700
Model: 2700
Slide: Yes ________
« Reply #12 on: March 28, 2011, 07:29:47 pm » |
Ron, I did think about you when I was drilling my ladder legs, that you wouldn't have to do this. One advantage I've found with having the ladder is using it to absorb the impact instead of the mh when backing into an overhang while looking in the wrong direction. I've kept the dent in the top of the ladder to constantly remind me to look up as well as side to side--old dog, old tricks, old blunders..  . Now here is really lame: When have a ladder and you back into the gutters it's not near as hard on them and you only leave two half round dents. Ask me how I know after seeing my neighbor do it to 2 grand worth of new guttering.
pyrthkr
« Reply #13 on: March 29, 2011, 03:54:49 pm » |
While co-pilot was shampooing the carpets I drilled the requisite holes into the ladder brackets & came out w/only a weep in 1 of them. Must be the "Dry Heat" of Arizona!  Full wash today & oil change later in the week (I almost soiled myself when the local RV dealer AWA "quickie" lube/oil change shops quoted $70-$100 w/o the oil or filter!). Father-in-law has ramps & drain tubs & I sh/be able to figure it out from there.
IntColor: Sterling
ExtColor: Sterling
« Reply #14 on: March 29, 2011, 07:36:37 pm » |
Dry heat is still heat! We're 90+miles north of Phoenix, so it's a little less dry here. Still can't figure how so much water got in my ladder--must be condensation. You can certainly beat the cost of your local rv dealer for an oil change. I buy the oil and filter at walmart, crawl under (it's high enough for me without ramps) drain the oil, change the filter (it's in a convient location and easy to change and fill up with new oil in less than 20 minutes. While I'm under there, I also lube it since I have the time--and all for less than $20.
