Another tip we picked up at the factory. If you happen to have to fix a small gouge, scratch, gash or maybe just a big hole in your floor use "SEAMFIL". The two colors that you will need are 904 (TAN) and 941 (Almond). As seen here on amazon
http://www.amazon.com/Almond-Seam-Fil-1-Oz-Tube/dp/B0006G84W4/ref=sr_1_4?ie=UTF8&qid=1333992351&sr=8-4. You mix them together to get the color you need for the area you have to fix, apply, let setup and only you will know where that repair is. I mixed the two colors together with a toothpick, applied a small dab and then ran a straight edge across the top to smooth it out. It looks great if you can find where you repaired it!
