Scan gauge 2 transmission fluid temperature
  • 10 Replies
  • 1196 Views
tswhitewater
  • 49
  • PurchDate: April 2018
  • ModelYear: 2018
  • IntColor: desert sand/cherry
  • ExtColor: toast
« on: April 25, 2018, 03:50:53 pm »
I have a 2018 E450 and SG2.  Iíve loaded every Xcode Trans Fluid Temp (TFT) series I can find without success.  Any suggestions would be greatly appreciated !!!!í
fandj
  • 233
Re: Scan gauge 2 transmission fluid temperature
« Reply #1 on: April 25, 2018, 04:43:43 pm »
https://www.phoenixusarv.com/community/index.php?topic=2406.msg19298#msg19298
This post lists the codes I used on my 2016 E450 with 6 speed transmission.
tswhitewater
  • 49
  • ModelYear: 2018
  • ExtColor: toast
« Reply #2 on: April 25, 2018, 07:56:00 pm »
Thank you, Iíll give them a try in the am.
tswhitewater
  • 49
  • ModelYear: 2018
  • ExtColor: toast
« Reply #3 on: April 26, 2018, 03:25:30 pm »
The codes worked, thank you very much!!!
fandj
  • 233
« Reply #4 on: April 26, 2018, 04:45:17 pm »
Glad the codes worked.  I have found the Scan Gauge useful.  I typically monitor transmission temperature pretty close when ascending mountain roads as well as when the engine is providing significant braking while descending. I target a maximum of about 207 degrees maximum to extend the life of the transmission.  I see about 203 degrees on relatively flat interstate driving.
I think having the ability to monitor real time miles per gallon has helped in adjusting my driving style to reduce fuel consumption.
Not a biggie but I usually keep up with outside temperature by viewing ďIntake Air TempĒ.  While traveling at highway speeds the SG temp matches very close outside air temp.
Bill G
  • 49
  • The Midnight Rambler - Andersonville National Cem.
  • PurchDate: November 10 2016
  • IntColor: Nightscape
« Reply #5 on: May 03, 2018, 03:05:00 am »
So what model scan-gauge do you have and how do you have it mounted?  tymote
Bill G.
tswhitewater
  • 49
  • ModelYear: 2018
  • ExtColor: toast
« Reply #6 on: May 03, 2018, 06:53:51 am »
Scan guage 2,   I have a dash rug and simply used Velcro to mount the gauge just under the handle on the drivers side.  I pushed the wire under the rubber seal on the cab side of the door.  It works vert well
The McDucks
  • 48
  • PurchDate: 9/2017
  • ModelYear: 2018
« Reply #7 on: May 04, 2018, 01:35:09 pm »
The friendly techs at Phoenix installed my ScanGuage II in the dash when I took delivery of my 2552 last February. It took less than 5 minutes. They removed the (useless) coin-holder insert in the E450 dash and with a dremel tool cut an opening in its back to fit the scan guage, then popped it back in the dash. Very convenient location and it looks like it was built in by Ford.
See the attached picture.
John
tswhitewater
  • 49
  • ModelYear: 2018
  • ExtColor: toast
« Reply #8 on: May 04, 2018, 02:18:15 pm »
very nice
Bill G
  • 49
« Reply #9 on: May 04, 2018, 09:51:42 pm »
Great location, just need to figure out how to get it out off
Bill G.
Joseph
  • 464
  • PurchDate: 3/7/2015
  • IntColor: Tan/Cherry
  • ExtColor: Gray / White
« Reply #10 on: May 06, 2018, 09:54:52 am »
I mounted mine in the same spot however I surfaced mounted it over it so should I ever sell - trade etc I can take it with me. That location is about as good as I could find for seeing what I needed with out distracting me too much from the road.
Iím really impressed on how accurate these scan gauges are. Iíve done several non stop tanks of fuel and checked the mileage against what the scan gauge states and itís always been within a fraction of each other. No more than what could be the differences in topping it off. I use mine mostly to keep an eye on the transmission fluid temp and engine coolant temp. The tranny fluid temp is critical in knowing when you may need to do a hot flush.
