Black & Decker Li-ion tire inflator
  • 9 Replies
  • 200 Views
  • 202
  • IntColor: Beige / Maple
« on: April 17, 2019, 12:12:20 am »
This thing is sweet  2o2
3-Way power - 12VDC, 120VAC, 20V MAX battery options.
https://www.lowes.com/pd/BLACK-DECKER-12-Volt-And-120-Volt-120-Lithium-Ion-Air-Inflator-Power-Source-Battery-Car-Electric/1000330671
I used it today with my B&D 2.0AH leaf blower battery to adjust my rear air springs and all 6 tires prior to installing a new TPMS . It adds one psi to the programmed setpoint, and the digital gauge agrees with the “gold standard”  Accutire MS-4021B. Comes with adapters for water toys and air mattresses too.
« Last Edit: April 17, 2019, 04:22:16 pm by CalCruiser »
Just Truckin' Around
bftownes
  • 186
Re: Black & Decker Li-ion tire inflator
« Reply #1 on: April 17, 2019, 08:30:29 am »
I used it today with my B&D 20AH leaf blower battery to adjust my rear air springs and all 6 tires prior to installing a new TPMS . It adds one psi to the programmed setpoint, and the digital gauge agrees with the “gold standard”  Accutire MS-4021B. Comes with adapters for water toys and air mattresses too.
Does it take "forever" to bring a tire up to desired level?    I have a CO2 tank that I used on my DP tires.  It worked great to bring pressure to 100 lbs, but it is getting more and more difficult to find a source to fill it.  Since I no longer have a full basement, it will take up a lot of room in my Toad.
Thanks for the heads-up on this product.
Cheers  :)(:
Barry T
  • 202
« Reply #2 on: April 17, 2019, 01:06:20 pm »
Running on the 20V battery or AC it’s much faster than any of the 12V models I’ve had,
although I have not used it on 12V. I was only adding 5psi but it finished one tire while I checked the pressure on the next.
bftownes
  • 186
« Reply #3 on: April 17, 2019, 02:04:49 pm »
Thanks.  I think I will get one.  My Lowes location is showing two in stock.
Barry T
  • 202
« Reply #4 on: April 17, 2019, 04:15:32 pm »
You will need to buy a Li-ion battery too, but even the 2.0 AH max is still much cheaper than a comparable Dewalt, Ryobi, etc.
« Last Edit: April 17, 2019, 04:21:56 pm by CalCruiser »
bftownes
  • 186
« Reply #5 on: April 17, 2019, 04:20:48 pm »
[/quote]
You will need to buy a Li-ion battery too, but even the 20AH max is still much cheaper than a comparable Dewalt, Ryobi, etc.
[/quote]
I was under the impression that it can be used without a battery by using a regular electric plug?  Is that not correct?
Barry T  :beg
  • 202
« Reply #6 on: April 17, 2019, 04:29:03 pm »
Runs on 110v AC too, battery not required.
  • 4077
« Reply #7 on: April 19, 2019, 04:44:24 pm »
I see my Black and Decker 4-10-20-40 amp charger with start feature is no longer sold.  It was re-styled a few years after I bought it.  I can't find anything like it, not even under other brand names as was the case.
This is the one I have and really like a lot.
The cooling fan inside failed once so I installed a high quality industrial version.
This is the redesign.
« Last Edit: April 19, 2019, 04:49:27 pm by Ron Dittmer »
  • 48
« Reply #8 on: April 20, 2019, 08:27:35 am »
Many jump-starters like Ron shows here have an air pump also and are a must have item anytime I go anywhere in any of my vehicles (when I remember to grab it that is.)
That and cans of fix-a-flat.  A jumpstarter is a much easier way to be the hero when someone's (or your own) engine won't turn over.
Dougn
  • 4077
« Reply #9 on: April 20, 2019, 09:07:22 am »
Dougn
My thought......
The ones I see for sale today, the amperage have a 15 amp max output, not 40 amps like my older one.  The 15 amp version is fine for regular vehicles with a single battery, but the 40 amp version is idea for a motor home with a pair of house batteries begging for a quick recovery via the Onan generator.  My on-board Tripp-Lite converter/inverter has a 20 amp max output, more than the new portable one.  At that point, my main reason to have one has ceased to exist.
« Last Edit: April 20, 2019, 09:10:07 am by Ron Dittmer »
